PM400 - No PTT ID alias?
Brandon_K
Pittsburgh, PA
It's quite possible I'm blind, but does the PM400 not have an alias list?
It's receiving the pre and post MDC from my HT's, but it of course only comes up as the individual ID. I can't find anywhere in CPS where to create an alias list. Am I blind or does this not exist?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
When looking at the tree in the CPS, Call --> MDC has a button to Add MDC Call. That will create a new blank call named MDCCL2, etc. Create the call, set your drop downs and Individual ID as needed. Then, place your cursor on the MDCCL2 in the tree, left click to highlight, and right click for a short menu. Now you can Rename it. Renaming it creates the alias.
Add another call, edit as needed and rename.
Repeat as needed. Now you've got your alias list.
SteveC0625
I'm delighted that someone else was able to find this thread and make good use of the info so I am adding some search tags to this thread to make things much easier for future searchers.
Search tags: The Commercial Series of radios included:
CP150 CP200 CP200XLS CM200 CM300 PM400 PR400
It may be helpful to search using wildcards. If someone asks a question about one model, the answer usually pertains to most, if not all. They are all programmed with RVN4191 CPS.
