Pm400
GearJammersc
SC
I've had a pm400 for a while now it's the 45 watt version. The problem is just the other day the power just dropped on it. I thought maybe it over heated. Power according to my power meter shows 18 watts on low and high power now. The radio in the CPS was set at 25 watts low and 45 on high. Now it will do only bout 18 watts. Is the PA going out? I've tried different power supply and even reprogramming the radio and same results.
a417
How did you become aware of the power drop, prior to you putting the meter on it? Do you have friends with test gear who can try aligning it ?
Tech21
Drop the low power to 1 watt and see if that helps. When was the last time it was tuned? If you haven't tuned it since you got it...
Do you have tuner software? If so, check power out while it's on tuner. If it's still low, yeah, your PA is probably toast.
TampaTyron
Tampa, FL
Do you have a different antenna or dummy load? Different power meter to try? What type of power meter and jumper are you using?
GearJammersc
SC
Only thing i know is i was on a ham repeater. The person i was talking to said your first transmission was good, but second transmission was noise. I then went to another radio i was getting in fine. I then took the pm400 put it on my mfj power meter on a dummy load all i got was about 18 watts. I then unhooked radio from power and let it sat for bout a hour. I hooked power to get checked power again still 18. The lowest power to be set on radio is 25 watts. This is a 45 watt version. It doesn't matter what power level you on high or low still 18 watts. I did hook up another radio cm 200 and its showing correct out put.
GearJammersc
SC
Nope i was told maybe those radios have a two stage amp in them. It's possible one side has burn out.
