PMMN4106D Remote Speaker Mic with audio adapter questions
ohio64thffemt
Ohio
We have the new Rugged RSM for our APX 6000 XE radios. It has the volume and also channels selector on top. It also has light on it. There is also a light on top with a Bluetooth symbol beside it. There is not a 3.5mm jack so we figured this was to Bluetooth like an earpiece or something to the RSM. Does or has anyone used, messed with this? Nobody seems to have a clue about this from where we bought them. Any and all info would be appreciated.
Tech21
If you ordered it with Bluetooth and not the connection that goes to the side of the radio, Bluetooth has to be enabled in the codeplug and you also have to turn on Bluetooth on the radio if your radios are bluetooth capable.
If your radio is bluetooth capable, go into settings through the front panel and turn on Bluetooth.
https://co.summitoh.net/800mhz/images/stories/PDFs/Radio_Manuals/apx6000xe_1.pdf This is the use guide and should help.
ohio64thffemt
Ohio
The radios have Bluetooth enabled in the code plug and turned on. The radio is working with other Bluetooth RSM that isn't what I am asking. Let me get a picture and attach it.
ohio64thffemt
Ohio
It's a corded mic that hooks into the side of the radio already. What is the Bluetooth setup on it? Is it for an earpiece or something?
897478974989750
Tech21
My bad, I misunderstood the question. That is just an indicator for what the bluetooth is doing on the radio. If you had a wireless mic, that indicator would be green to show it's connected to the radio. Since yours is wired in, its not used.
K2NEC
So you could have a wireless mic hooked up to the radio while simultaneously having a wired mic hooked up to the radio?
ohio64thffemt
Ohio
They don't make that type of mic in Bluetooth/ non cable. That's what I am trying to figure out there has to be another reason or option. It doesn't have a 3.5 mm jack so I was wondering if they was part of it.
KK6ZTE
California
It sounds like its just a remote indicator for the radio's bluetooth radio status. None of the documentation states that the mic has it's own bluetooth radio.
firebuff17
CT
I get that it’s an indicator of the status.
I am curious if I can connect a Bluetooth speaker mic that would be connected to my scba face piece All the while still having my wired XE500 RSM hooked up.
ohio64thffemt
Ohio
We already have this with the G1 MSA and it has nothing to do with the RSM. You do it with the Bluetooth from the APX radio alone. You don't need the RSM. All you need is to PTT the side of the radio or RSM.
ohio64thffemt
Ohio
You also can't Bluetooth the G1 like other Bluetooth accessories. You have to have the MSA read writter and a fob. It's set up that way so they don't cross pair during operations.
