PMR446 -> Stron Signal -> bad Sound
Your_account
Banned
.AT
Hey
I am in my City in the Railwaystation and i discover the PMR446 Band for some interesting Voice and i recive some but i cant understand because the Quality is sssoo bad. Many Noise .
Can i do something to get a bether voice?
LATA 722
Try a better antenna. PMR446 is low power with inefficient antennas by design. You can improve what your receiver hears by using a higher gain antenna.
Also, I believe PMR uses narrow band (2.5kHz deviation), so if your SDR has a narrow band FM setting, you can try that. Using wide FM on a narrow band signal can cause low audio level.
Your_account
Banned
.AT
I try only NFM. Next time i will try WMF to. Thanks
Do you know an good Antenna for that Band wo work white some other interesting Communication to?
