empireco
My Lorex HD security camera system has been destroying my VHF Lo reception for a long time now.
I recently changed from the factory supplied cables to the cameras to shielded Ethernet cable and connected all the shields to a 14 gauge wire that runs strait to the negative on the 12 volt power supply which is also hooked to the House ground. I rerouted several cables to get them as far away from my radios and coax feeds as possible. That did not stop the interference. When I unplug all the Ethernet cables from the Lorex NVR or switch the power off, the interference disappears.
Does anyone have a suggestion to eliminate the interference besides stopping using the system?
