Pomona PD
flugpop
Alta Loma California
Can someone confirm is they are encrypted? I am using ARC396 and have put the system and I can hear control channels but no audio at all. Under system type its set as "Motorola Type 2 UHF" Is that correct? Thanks in advacnce.
flugpop
I'm trying to find out if its encrypted currently. There is conflicting things on that thread. I would like to know the current status. Thanks
brandon
SoCal
Pomona PD Blue-1 (Dispatch) is clear. Everything else is encrypted. When programming the UHF system make sure you entered the base, spacing, offset.
See this for more info: http://www.radioreference.com/apps/db/?sid=2856 (scroll down to Alternate Custom Frequency Tables and use the info for Pomona)
