Poor reception PRO-2026
Mikeg5513
Parma Hts Ohio Cuyahoga County
I was going through some things stored in the basement and I found my Great Uncle's old Pro-2026. I had forgotten he left it to me when he passed about 3 years ago. I hooked it up, and it workes, Kind of. I programmed some known freqs in my area. It didn't seem to recieve. I tryed a couple anntennas that I have, and the antenna work just fine on my pro 95, pro 63, and pro 2015. I opened up the scanner and found that the solder point between the board, and the BNC had broke. I resoldered it thinking it would fix the problem. Well it didnt. There are 2 mods done to this scanner. I dont know who did them, and I cant really ask my uncle.... The fist mod is a toggle switch for the back light. It seems to work as it should. Although if you flip the switch up and down (on and off) there is a tiny bit of audible "popping". The next mod is a 9v battery soldered in line with the power supply wires (on the board). I guess this scanner losses memory? I remember when I was a kid that this scanner worked just fine in my Uncle's appartment. Is it possible that over the years it has just gone bad? One thing I did do was program the FRS freqs into the scanner and it will pick up FRS at very close range, like at 2 feet. I really dont have the means to see how far i can get from it to find out the range. Any ideas? Is it possible that someone messed with somthing on the board to affect its sensitivity?
Mike
Mikeg5513
I dont need a link to the manual.. I need some advise on how to see if something can be tweeked inside. Is there a way to mess with the Gain? It looks as if someone tweeked this scanner in the past.
buddrousa
Mike the solder joint on the antenna will work as for the tweeks I say you need to find a service manual with tuning specs and a good service monitor and retune the scanner just turning pots blindly will not help matters
