meridiangold
- Joined
- Dec 2, 2021
- Messages
- 53
Still learning how the 436hp works. I've noticed my 436 is pretty deaf in the 155 to 170 Mhz range. I'm comparing it to my RS Pro528, which has awesome sensitivity with just it's rubber ducky. I've connected the 436 to two different antennas in my loft with poor results on the 436 but awesome results with the pro528. Of course reception improves noticeably on my 436 when mobile and a different 2m whip like the one in my loft. I modified the loft antenna by adding a substantial ground plane, sort of. I'm going to trim that one more specifically for the range I mentioned. A proper outdoor antenna will happen when winter passes. I did crank the AGC/DGC settings with no improvement. My squelch sits at two. The air band works awesome as does a lot of the UHF band(s). Has the 436 been shown to exhibit this behavior? I wonder if UNIDEN knows this and might work out the algorithm in a future update. I'm not exactly in a signal dense area, but the Pro528 outshines the 436 hugely.
