sefrischling
Public Information Officer
So, what are you all using for the P25RX as an antenna?
When I use the newly acquired P25RX with the SpectrumForce Wideband Antenna it works fantastically.
When I switch that to a 700-800mhz "rubber duckie" so it can be affixed to the back of a Toughbook I get nothing. Ideally, the P25RX will be primarily used affixed, via Velcro, to the back of a CF-19 Toughbook, which makes the SpectrumForce antenna impractical.
I have tried to use the portable antenna in a few locations and I get nothing, it will see no signals, while the Unication G5 has no issues.
So ... what are you all using when using the unit as a portable?
