Portable Radio Options
Unit475
NC
I have been looking at buying a Motorola VHF 16 channel portable radio. Was not looking to spend a lot on it because I would not use it that much for talking however a lot for listening. I would like it also to have Quick Call in it for fire tone out.... What is my options???
Price range $170-$200
I noticed on ebay someone in Hong Kong has the Motorola GP340 and they clame they have Quick Call II Signalling however I can not find anwhere in the OM for the GP340 that it has that so im scared to trust that!
Help me out please!
-Thanks
Unit 4-75
KE4NYV
Williamsburg, VA.
Honestly, avoid overseas models if you can. They typically require a different version of RSS than the US versions. This not always true, but I have ran into it more times than not.
As for VHF 16 channel Moto portables, look at the HT750. It's available in a 16 channel version and you might find one in your price range. Also, if you are willing to downgrade a bit, take a look at an SP-50+. You can find these in 10 channel units. Another option would be a P1225. You can also find these in 16 channel units.
Unit475
NC
It looks like they have been replaced with the CP radios???
They look like they have what I need...
Are they any good???
-475
Magnetsteve
Central Arkansas
-475
Sure, if you are mainly monitoring, the CP200 is a good model, they have 16 channels and have quickcall/MDC capabilites, and are usually fairly cheap.
Need a radio
Help me out please!
-Thanks
Unit 4-75
Unless you got your heart set on a new one, just find a used GP300 on Ebay, or post in the "Stuff wanted" area here. It will do quick-call, you can drop and it don't get hurt. Bats are cheap, the audio is nice and loud, you should be able to find one with a good battery for no more that $150.
chrismol1
Saratoga
P1225 & GP300 are very nice radios. You can use them as a baseball
There from the mid 90's but very reliable. They can be bought on ebay for around $75-$100
you can get many non-OEM batteries and chargers and accessories on ebay
The CP200 is a rock too, I've seem them go for around $100(just the radio)
The HT750 is great also, seem them for around $100, accessories are everywhere
These are non-display units, I'd go with an HT1250 if I wanted the display but they cost a bit more
I'd personally try to go for a newer model, I'd shoot for an HT750 or HT1250.
Unit475
NC
I was looking something kinda small and newer then that! Im looking at the CP200 16 channel VHF but they are about $270 per unit! A little high for my price range!
chrismol1
Saratoga
There are some really nice ones on ebay, but you might have to find the charger, batt, ant seperatly
KE4NYV
Williamsburg, VA.
I forgot about the CP200. That is also a great option. Better yet, the PR400 is better, 16 channels and you can even find them with an LCD and full DTMF keypad. Programming cable is easy to make for them too :D
Unit475
NC
I have a ??? about the PL tone setup for the CP200
My county fire channel pl tone is 186.2 Hz but if I recall right I think I heared that if its set up as a tone SQL that it will not work. It has to be set up on a tone ENC. Our fire and so channel is like that however our rescue channel is a tone SQL but will work with a tone ENC.... How would I explane this to the person programming the radio? Or dose the radio came in tone ENC to start off with???
Thanks,
Unit475
