hey guys I put up a feed for Portland, South Portland, Scarboro, and USCG Ch.16. Let me know what you guys want to change or add. Scanner location is near the jetport
Seems to have alot of hum, wondering if the desktop input vol is turned up and the radio vol is set low or is the other way around that does that? Just might want to check your input audio lvls. Tough to listen too.
Hum equals ground loop. The scanner output is high also, but not the cause of the hum. What is needed is a ground loop isolator. They can be made from an audio transformer and placed in line or can be purchased from Radio Shack. Hum can be fixed easily.
Hello any chance of tagging the BCT15, its not easy for us who are not from the area to id who is talking or what City is dispatching>??? Thank you again for providing these scanners
I am not sure which feed you are specifically talking about, however I can tell you that the "Portland and South Portland Fire and EMS" does have tags enabled. If you are talking about the other Portland feed, I believe he is using a BCT8, which correct me if I am wrong is not alphanumeric.
