Portland Rebanding
Baker845
anywhere
Is there web sit that we can find out what the new 800mhz freqs are going to be for Portland metro area? or any 800mhz system in oregon?
thanks
UPMan
In Memoriam
Arlington, TX
Two steps:
1) Look up the system's FCC ID in the database here (click on the site name).
2) Use the lookup tool at www.800ta.org to see what the changes will be.
DickH
icom1020 said:
I'm going to wait to purchase any radio until I read more on this, here is a wiki site on rebanding
http://wiki.radioreference.com/index.php/Rebanding
The WIKI site is a bit misleading. They talk about UNIDEN and RADIO SHACK scanners, but that is not a clear distinction because some RS scanners are made for them by Uniden and others are made by GRE. So the distinction should be Uniden and GRE.
joescanner
Just another radio geek.
Gresham, OR
It IS a wiki, so why don't you sign in and change it?
Some of the radios are being reprogrammed starting Q4 (thats this month), but the city is doing it in stages, and it will probably take between 6 and 9 months to get all 8,000 subscriber units.
scootz
Metro PDX, OR regional area
And that I don't think includes all of the outside radios from Clackamas, Washington, and Clark counties either.
Going to be a long, tedious process. Going to be a lot of coordination between all of the agencies to go through this process.
It will be fun for all :lol:
Baker845
anywhere
Are they reprograming moble,portables and repeters? Do they have to replace any? Im not up to speed on how Motorola 800 mhz radios work?.
thanks
DickH
thanks
Every radio is affected. If it can't be re-programmed, it will be replaced.
MrBarbecue
Salem,OR
Given the time frame mentioned above about the change-over, do you suppose that PDX will be using both systems until they have completed the change-over? I can't imagine having a portion of the rebanding efforts being used early on, while other agencies are still waiting to re-band their operations. Any thoughts on this? Inside information?
Also---has anyone heard anything about re-banding in Salem yet?
Thanks!
N
N_Jay
Guest
Thanks!
If the rebanding is done right it is fairly transparent to the users beyond bring their radio in for reprogramming or replacement.
DickH
Thanks!
All 800MHz trunked systems in Oregon are (or should be) following the same schedule. Phase 1, 0-120 channel reconfiguration, was to have been completed by July 1, 2006.
That involved moving 0-120 freqs. (851-854) to 854 to 860. That has been completed in Portland.
Phase 2 involves moving all the 866-869 freqs. down by 15MHz. That can only start after everyone has moved off the 851-854 freqs.
A search of 851-854 reveals signals still present there as of yesterday, 10-15-06.
Phase 2 is scheduled to run from July 1, 2006 to Dec. 31, 2008.
N
N_Jay
Guest
The schedule given by the TA is one thing.
The schedule developed by whoever is rebanding the system is another.
It's not like the TA, the FCC, or Nextel is doing the rebanding!
DickH
guus24 said:
Is clark county going to reband on oregon schedule or on the washington schedule?
It is not clear if they will or not, but it would make sense to do it now along with the 3 nearby counties in Oregon. But you know how some people procrastinate. :)
N
N_Jay
Guest
Washington is part in wave 2 and part in wave 4.
K7AAY
Oak Grove OR
Wiki spawns new questions
That WIKI suggests many RS systems (those made by GRE) won't properly receive Motorola systems because of the reduced channel spacing. Since Portland has a Moto system, this suggests Uniden-made scanners are the way to go as halving the channel bandwidth was said to be a problem for GRE-made RS scanners. Is this accurate?
73s and best regards
DickH
Keep in mind that WIKI can have info. added to it by anyone. I take some of what I read there without much credence.
