Posey County Going NXDN...Questions?
ramblin82
Can some one that runs dsd plus check Phillips station LCN some one just told me he think lcn 52 has changed as to a new freq?? He runs lcn finder with his 536 for over 5 hours and as of late never shows the lcn 52 does show 51,53
thanks
CH IDFrequency
51154.7475c
52155.085
53155.625c
I just checked the site on DSD, the neighbors list are still the same. The only ones that populated were lcn 51 and lcn 53 which are still the same. I will check again around 2:00 AM when they rotate the CC channel and see if lcn 52 is still the same. If it's changed then it could be due to another NXDN96 (RAN:0) system that has been interfering with 155.085 for a good while now.
Ch 51=155.7475c
Ch 52=will check around 2:00 AM
Ch 53=155.6250c
ramblin82
I've been monitoring 438-5 with DSD+ since they rotated CC channels and still only seeing lcn 51,53 being used. I then made a fresh DSD+ folder without programming any info into DSD+ and the CC channel populated a blank lcn 51,53 but no 52.
Ch 51=154.7475
Ch 53=155.6250
You're correct lcn 52 appears to be gone, they might have changed it due to that NXDN96 system causing interference on 155.0850. I wonder if will stay just 51,53 from now on?
appalling_hauling
mt vernon in
Yesterday dispatch called 15 Adam 3 to an address on Nation however he was on a complaint in Poseyville yet the St.Phillip tower got both parties.
If nothing else this is a learning experience
ramblin82
That's the only source I have now
After a new SD card and much experimenting with settings on my TRX-2 it's now performing almost as good as DSDPlus. The BCD436/536 you mentioned should be picking up the system just fine as they will follow the control channel, which TRX models won't. If you're in town you should only need site 438-1 which comes in strong.
I've offered to look over your TRX settings in past (CDAT zip file), but heard nothing from you.
appalling_hauling
mt vernon in
The water tower at Lamont and Keck bypass is up but no antennas mounted as of yet. The crew is still working on the tank.
Leave it to Mt Vernon to mount a lightning rod on level ground next to the Evansville Western Railway mainline. Im glad they didn't get wise and put a repeater up in Bufkin for height because we have enough lightning rods up here.
They make thunderstorms happy but unnerve everyone beneath them. As if we don't have our peace disturbed enough by idiots with distorted subwoofers trying to get everyone to pay attention to them.
Of course the sheriffs department can't be bothered to shut them down regardless of the time.
appalling_hauling
mt vernon in
Speaking of which Im not sure of which talkgroup this tower will be but Im not concerned because the resources here are better than spreadsheets.
The scary thing is that the folks on here know more what's going on than the people putting this system together.
I know. What do I expect? Expertise by the professionals? LOL!
