Hi folks.
I'm new to the scanning thing ... so new I'm still in the planning stages of buying my 1st scanner, antenna, coax, etc. I'll mostly be listening to the 800Mhz band on my new base scanner -- it'll be a Uniden 996T when I order it.
I want great 800Mhz, omni-directional reception but want to do it without putting an antenna outside of my house. So my choices, I believe, are either an 800Mhz duckie on the unit or an antenna up in the attic w/ coax run to my scanner. I see that a number of folks (and some kind of study) says the Seeker duckie is the best duckie for 800Mhz. My question, finally
is would you just attach the Seeker to the unit or would you put it up in the top of the attic and run coax to it? It would be <= 25ft of coax (probably RG6) from scanner to the attic. Putting it in the attic would probably raise the elevation of the antenna about 12-15 ft. Another option I guess would be another type of omnidirectional 800Mhz antenna in the attic ... but I don't know of any others better than the Seeker duckie.
Thanks for all of your advice. I have learned bunches from reading all your RR forums!
-Dan
-Dan
