Possible encrypted traffic on AWIN
bubbaearle
At around 9pm I heard what sounded like encrypted traffic on TGID 16425 - possibly Jonesboro Police.
I looked to see if it showed DG and not VC - sure enough it was DG and it didn't sound weak........had full bars on the S meter.
I caught this on the Wynne tower by the way.....
btritch
16425 is not in the DB at all under anything in Craighead County But It could be, i don't listen much because of the online feed, I'm fixing to get a splitter and split the audio off so I can start hearing it< if I catch anything I'll let you know but I've not heard it, I'll keep my ears open though.. Thanks for passing that along
bubbaearle
Correct, it's not listed in the DB.....
16425 is in the block of TGIDs assigned to JPD so it's just a guess.
btritch
True, It was late when I read that post and didn't think about that, Good Point. I'll listen and see what I can figure out..
bubbaearle
I loaded this on my AWIN system just now. I'll see what I can figure out.
I picked it up as a WILDCARD hit
I have a TSYS set up with all of the known TGIDs in the DB but they are locked out and then I have WILDCARDS that are enabled.
k5rpd
Springfield, AR
Jonesboro PD and Fort Smith PD are two departments that I can confirm are using encryption. I do not know what flavor Jonesboro is using. Fort Smith is using AES. Almost all of the subscriber units in Pope County have ADP encryption that is not being used currently.
