Possible to control scanner via internet?
trainerman
California
Hi,
I have a Uniden BCT15 in one area of my house that I would like to be able to control from another part of the house by my internet connected laptop. I have heard that this is possible by software, but what software and how?
Thanks for your time!
SonicN
Hi,
I don't know your radio, but if you got software that can control your radio, just install this, and hook it up to your radio. Then use "remote desktop", use another computer, log on to the computer that you radio is hooked up to, and voìla...
ProScan
Software Provider
Ontario, Calif.
Hi,
My program, ProScan can do exactly this with streaming audio. The 30 day demo is fully functional.
www.proscan.org
brandon
SoCal
Yep. I second the ProScan choice. This is by far the best and easiest method for controlling your radio.
smason
Alberta Canada, Eh!
I use Proscan for this, and not only can I control/listen from any computer on the net, I can also use it's web server and stream it on my iPhone, no control, but great audio.
trainerman
California
Re:
Thanks for all the replies and help. So if I go with Proscan will I be the only one who can view and control the scanner or can anyone with the ip address view/control it?
ProScan
Software Provider
Ontario, Calif.
Yes and No. If the ProScan server and client are on the same home network and you don't setup the router port forwarding, then only the server can be accessed from within the home network.
If the router port forwarding is setup to allow ProScan traffic on the port specified, then any one can access it provided they know the IP address and port.
N2JDS
St. Peters, Mo
As a free alternative, I use logmein.com
They have a free version. When you log in, it's just like being logged into your computer that scanner is running through, then you just open up your software to do whatever you want to. This will work from anywhere in the world into your computer. I've reprogrammed mine and changed setting while at work many times.
St. Charles Countywide EMS, Fire, and Law Live Scanner Audio Feed
trainerman
California
Thanks for all the great suggestions and help! I have decided to stick with my Uniden software and use the free service, logmein.com for controlling my desktop service remotely. Great stuff...thanks for the suggestions about using remote desktop control.
