Luis_C
Hey guys, I monitor aircraft transmissions, I use a Pro-95, and a center loaded telescoping antenna for now. But I have noticed, that the Pro-95, is really sensitive to interference of all kinds, most of the frequencies I listen to, at about 48% schelch, I listen to all kinds of strong interferences, almost everyplace that I monitor, and really crappy signal, sometimes there's luck and works ok, it would always work ok, so I believe a AOR ABF125 filter would really help, problem is, I can't order here to Mexico, it will become tad expensive, and the customs here when they see weird stuff, they don't let it pass, and I'm not sure if Universal Radio would ship it for me. But I have student friends, currently not there because of vacations, that could receive it for me, but that would be in a few months.
So I was wondering if I could do a bandpass filter but homemade, I don't really care if it gets a big box, because I almost do all my monitoring being on base, (simply I mean that I get all my stuff in some place, and I sit there and enjoy, so carrying something extra doesn't matter.) and if it won't work as good as the AOR, but if it will help that's great.
I saw this: http://ourworld.compuserve.com/homepages/Bill_Bowden/opamp.htm#bandpass.gif Wonder if it would work, I'd do it but I'm confused with the formulas, I don't know what Q and Gain should I use, if someone can give me some help I'd really appreciate it or another ideas would be great.
What I also noticed is, that going near my airport, or when there's good propagation is that I can pickup the center that controls the sector here, that isn't controlled by airports clearly, actually the center is at Mazatlan, 400 miles from here, giving instructions to airplanes that are really far of my city, I sometimes can't pick them up, but I have a clue of what's going on with the traffic, here the pilots sometimes don't repeat instructions, or they say it really fast, or they kinda abbreviate it, but the controllers know that they are right, so pilots are harder to understand. A guy also has noticed that in major airports his reception is great, so he asked to pilots and stuff, and there seems to be some kind of repeater or something, that helps. And personally here, listening to the Center, and Tower, complete fun.
So I was thinking that I could buy a TV VHF Yagi Antenna, and modify it for Airband, changing the elements length, separation and everything, get it as tall as I can, (security first) for pickup the airport. Luckily, there's not hills nor tall buildings that could affect, and it's only about 6 miles.
What do you guys think?
Edit: I already tried a home made ground plane antenna, I didn't had really good results, I was thinking that I should better do a J-Pole, because it is really popular for airband and it provides 3dB of gain, when the ground plane doesn't provide any, but I have to get tools for be able to solder and stuff, that shouldn't be much of a problem, but probably the Yagi solution would be the easiest one.
Edit2: It would be easy for me to buy a CB antenna, do you think it would work crappy, or it has a chance?
