Possible Tunnel System in Hampton Roads?
Larry51
Chesapeake, VA
I picked up a weak voice signal on 853.4875 last week. I searched the FCC listings through Radio Reference and found a low power system of repeaters and mobiles that I wasn't familiar with. The call signs associated with the system are WQOB581, WQOB582 and WQOB583. The transmitter sites are located at the various tunnels in the Hampton Roads area, including the CBBT. The licenses are issued to the Virginia State Police.
Can anyone help me figure this out?
trumpetman
Charlotte, NC
That's the first time I've seen that frequency licensed for repeater use (at least around the Carolinas). I've always seen that referred to as the Motorola simplex channel. It used to be programmed into 800 MHz business radios for use when out of range of trunked systems.
Larry51
Chesapeake, VA
That's interesting. Throughout the rest of Virginia, outside of Hampton Roads, it appears to be licensed to Nextel as a cell phone freq.
Jim41
It is part of the STARS system. It is intended to let units communicate when they are inside the tunnel. Some localities are also given access to this capability.
Jim41
Webodisk
Mike
Virginia Beach,VA
853.4875 is Norfolks Simplex channel and also a multi use channel on the water front in Norfolk, the tunnel channels used to be tunnel a 866.4875, tunnel b 867.9875, Tunnel c 868.4875, with rebanding not sure how they reconfigured them
MIke
