N3JI
So I did the DMR upgrade and got it enabled, no issues. I have my local DMR Amateur repeaters setup and receiving nicely (after a few initial issues). I first tried setting up multiple sites with all the same TGs setup as channels since they are all standard for Amateur use. No dice -- it would see the RF (signal strength meter was showing strong levels), but it wouldn't stop on a channel or decode any audio. Deleted that and set up each repeater as its own system and all was working well.
Then I tried setting up some simplex channels which have been standardized on 4 freqs: CC1, TG99, TS1. Tried multiple ways of doing it, but it will not stop on a channel or decode my hand-held no matter what I try (CC Search, ID Search, etc, etc, etc). I verified the hand-held is setup properly. No idea what I'm doing wrong here. Any ideas?
I also seem to have lost my P25 X2-TDMA reception. I have three systems that are X2-TDMA, but all I get is garbled noise when they are in TDMA mode. It stops on channels and shows the TS, but audio is just gabled random sounds. No issues previously. Some agencies on the systems aren't using TDMA, and they come in fine. What gives??
