Paul, still no luck with the extra packet.... I sent a EM 3 or 4 days ago.... Let me know man, my 396 is unusable!
Edit, Paul sent me an EM. He is in Tokyo.
mdulrich said:For MARCS try setting your P25 Waiting Time to 500 ms.
Mike
ravthree said:additional, after upgrade to 396t, reception problems with vhf high WESCOM broadcasts not previosly experienced. bolingbrook il clear signal recept, now loud humm that drowns out voice vhf high, kencom uhf was maxing out signal meter, now 0-2 bars w/ static , joliet and naperville trs 1-2 bars, now 0-1 w/ waves of static. plainfield and ill state pd crappy before, now apco 25 great sound. need to get this machine back to the great piece of equipt that i had before the upgrade.
Viper43 said:eavthree,
did you reload your scanners programming after doing the update? If not do that first. Also you can try the P25 timing and see if changing that makes a difference. Press HOLD, go to program mode and SETTINGS in the menu, scroll to P25 Timing, it will probably be set to around 400ms, try different settings and see if things get better or worse.
V
kb9sxk said:Mr. Upman
I am having the same issues that Mr. Viper had with the Indiana Safe-T system. What I do recieve sounds very strong. I think Im mkissing about 75% of the traffic. I will bring my actual system radio home tonight and compare it with the scanner. I have a few heavy use TG that i can monitor in both the radio and scanner to see what is up.
newsalan said:(My BCD396T)
Does not scan well with the newer firmware and Uniden "lacks" information about cause, fixes, anything regarding these problems.
Lately, every time I check something, or check old systems that I used to receive, or things that worked okay, like CC search, Type I systems, p25 systems and hold, the scanner does not perform well at all.
Also, a system that I could receive excellently at the 23 mile marker heading South, barely receives at the 19, picks up somewhat at the 13.5, and fades and drops alls the way down to the 10 mile marker. Before I had the system at the 23, and before that fade in and out north of that with reception beginning at the 26 or so with fade.
Today, Limit CC search missed A P25 systems. Holding on it results in a long delay; 1-2 seconds at least, noise comes through, then an ID.
Analog volume is still too low, digital is so so, I’ll still getting braaap, motorboating on Safe-T, maybe a little less, but the burst that comes through seems to hang in there longer now. In other words I get less of it, but it sounds for a longer time.
Analog is still too soft with volume adjusted for digital listening.
Uniden has a big screw up in my opinion. Every time I check something, it just leads to more problems.
My advice don’t upgrade… buying a new scanner, get a GRE, it works, has timely updates, is responsive, and they trunk rebanded systems right now. No possibly month long waits for another firmware update.
AL
donc13 said:Paul says that when folks had issues like your's after the update...to simply restore the backup and ALL the "new" issues go away.
500.00 shipped if you want it.donc13 said:Did you follow the instrucitons? That is...start with a backup of your scanner?
If so....then restore that backup to your scanner....then see how it works. Paul says that when folks had issues like your's after the update...to simply restore the backup and ALL the "new" issues go away.
The analog vs digital volume is adjustable...have you tried adjusting it?
and if you really don't like your radio...sell it. There's lots of folks here who'd love to have a 396.
If I hated something like you seem to hate your radio...I'd get rid of it.
