ecps92
or Depending on the make/model and image from the 460/465 Bands
It could be SCADA or intermod from some non-federal frequency.
i have a local pager on 929.xxxx that splatters all over VHF and UHF... (never mind my local EDACS 800 trunk that does the same...) luckily most of the old 450/150mhz pagers are gone these days. I would say that it's not completely unheard of to have a pager on UHF in the federal bands - but most all of them I am aware of these days are down in VHF 16x.xxxx - and are usually associated with a VA hospital.Does anyone know what the paging-like signals are on the federal bands? Right now on 418.1625 Im getting this signal which sounds somewhat like a POCSAG paging signal, but maybe a bit different. Is this something that can be decoded? I've also seen these on 162-174.
Ill have to see if I can hear it on two different devices at the same time next time I see it.
Today I got activity on 390.400, DMR, Color Code 2. Never seen that before, but I have seen 391.15 which was also DMR. Not sure what these are
They were heard on DSDPlus - but I have seen the same thing happen, so I think you may be right. I've got that frequency prioritized and so if I see it again, I'll see if I can get anything reliable from multiple sources. I'm thinking the 391.15 may be the same thingI get images from the 450-470 range in the 390 area. I'd suspect that's where those signals really are (assuming you are hearing them on your 436).
I usually use the same antenna at home with DSDPlus and my BCD436HP, it's a telescopic dipole (from the thread I posted, if you're interested).
Otherwise, I use a DIamond RH789 on the BCD436HP
Sorry - I worded that confusingly - I meant my RF source is the dipole antenna, going straight to my SDR.As has been hinted, since the RF source is the 436HP, it is likely an image
Best to see if you hear this also from another radio [hopefully a different make, but 1000% a different model]
or even an Amateur Radio that can RX out of band [not a CCR]![]()
That makes me wonder if someone is hiding their comms, pirating a fed freq.Okay, I could have sworn that I read a few posts from people in Florida indicating they've seen DEA using DMR, but I can't find them to save my life. Reason I'm asking is because I have been copying DMR encrypted, lining up with a definite DEA analog channel. The clear analog will Tx, then the DMR will respond (air-ground) - it seems to be way too perfect to be a coincidence.
Has anyone else seen or heard of this?
I dont know - the analog part of the conversation is clear - that part is definitely them, however Im too far to hear the ground portion. Its driving me totally nuts that I can't find this. I don't know where I would've gotten the idea from. The only thing I can think of is an image on that frequency, at the same time of the real comms, confusing the bcd436 and sdr.That makes me wonder if someone is hiding their comms, pirating a fed freq.
DMR and encryption in Florida? Unlawful importers of improvised pharmaceuticals perhaps.
I think they would only be concerned with the NTIA.
I was in Midtown Atlanta today and picked up 169.55 NFM unknown users talking I didn't catch the NAC code or the radio user id number when I was scanning in search mode for Federal VHF.
