No recordings. Just logs.
Sorry I didn't get back to you. I got some more dongles. Let me run Unitrunker for a couple months and then I'll post my file. The plan is run on Sauk Centre, Glenwood, Osakis, Long Prairie, and Freeport.yes we can. Be more then happy to share what I have found over the past 8 + years sharing my Unitrunker File.
Most of use record to ID stuff. Currently, I'm recording in Proscan to ID rid/uids. Also, recording a couple Unicom/CTAF frequencies to ID airfields throughout Central Minnesota. Also, have Unitrunker running also. @bearcatrp you should try Unitrunker also.We need a repository to post a file for others to check out if interested. Am currently recording for a week again to add what frequencies I am picking up in central minnesota. Would be interesting to see what others have recorded.
What does unitrunker do that the 200 can’t do? Just did a quick search and read some of the wiki page. Proscan logs and records. From what I read, pretty much covered.Most of use record to ID stuff. Currently, I'm recording in Proscan to ID rid/uids. Also, recording a couple Unicom/CTAF frequencies to ID airfields throughout Central Minnesota. Also, have Unitrunker running also. @bearcatrp you should try Unitrunker also.
I look at it as another tool in the "toolbox".What does unitrunker do that the 200 can’t do? Just did a quick search and read some of the wiki page. Proscan logs and records. From what I read, pretty much covered.
