Potential V0.4.0.36 PPS Bug with CPRM Talkgroups
eorange
♦RF Enabled Member♦
Cleveland, OH
I am in process of migrating from V3 to P4 PPS using the CPRM. I have many hundreds of talkgroups, so I decided to use Unication-format .csv files as (for now) my system of record. I imported all the .csv files into systems defined in the CPRM. I then created profiles based on the CPRM systems and talkgroups. I started out with just a few zones and everything works as expected.
Then...I realized my .csv files needed some updates, both TGIDs and how I named them. So I revised my .csv files, deleted all TGs from the CPRM, and re-imported into the CPRM. The CPRM now shows my updated TGs from the .csv files.
Here's where I'm encountering a bug. I thought it would be a good idea to delete my zones and systems and re-pull the systems and TGs from CPRM, so I did. Except now, when creating a zone...I see my old (original) list of TGIDs. The CPRM shows the correct TG list, but somehow the TG picker in the zone is only seeing my "old" talkgroups...which don't exist in the CPRM or directly in the profile. It's like they're cached somewhere. But I examine the TGs in the CPRM and they're the revised TGs.
My next step is to completely delete my profile and start over (which isn't a huge effort). Barring that...then uninstall PPS V4 and reinstall and maybe that will clear what's in the Program Data folders.
eorange
♦RF Enabled Member♦
Cleveland, OH
While you updated in the C tab did you also update in the E2 tab? Deleting the old in E2 tab and moving the new in from C
Arrrghh...I thought I did, but apparently I did not. That was it - thank you! (I blame it on spending too many hours on my .csv files.)
