ridgescan
Will my Icom AD-55A be adequate for powering the R8600? 16VDC, 1.5A. (tested at 19VDC)
Thanks.
Thanks.
Thanks.
Thanks prcguy. I posted this then had to hit the road. I picked up an Astron 13.8VDC, 3amp power supply there at HRO as I picked up the R8600. I didn't like the extra voltage from the AD55A supplied with my R75 either (too hot) so I have a Samlex 13.8VDC, 7amp running that rig. Glad I bought the Astron for the new R8600. BTW the R8600 is smaller than my R75-I did not expect that. Modern tech!
Not sure about unblocked-how can I find out? I do notice the Astron's heat, and the R8600 is just as warm itself! Should I run my boxfan behind it?The Astron should work fine but it will get a little warm with continuous use. We are now expecting a very detailed report on your R8600. Did you happen to get an unblocked version?
ThanksMy Pyramid PS8KX ran too hot to touch so I got the Astron 12-A. Stays cool - almost room temps and I often run it for days. Both of my Icom 8600's run well on it - I have a small desk fan blowing across them which helps a lot. Congrats on your new 8600 ridgescan - it's a magnificent receiver.
Ah thanks-in that case it's blocked.USA version which is blocked Serial # starts from 02xxxxxx.
Non USA version which is unblocked Serial # starts other than "02"
I don't know how the heck I missed your post prcguy-a belated thanks and sorry.If your S/N starts with 02 its a blocked US version and an unblocked usually starts with a 04. I was able to qualify for an unblocked US version and my R8600 is doing some US Govt work as I'm typing this.
Good to hear thatI am powering my 8600 with the Icom AD-55NS adapter. I was worried it might not provide enough power, but it has been working great, running cool. So far, so good.
Good to hear thatI joined the "Groups.IO" and some guy from Finland reported that his AD-55NS caused RFI in the lower HF bands but I think his was defective.
