Power Hookup Ford Explorer 2004
firemedic710
Logan, WV
I just bought a remote head radio. I don't have enough wire to go directly to the battery. I have a 2004 ford explorer. Where is a safe quick easy place to to hook up my power wire. Not sure where I can splice into to get power for it. I will put it under the seat. I have about 3 feet of wire. I am no mechanic. I would appericate any help thanks.
b7spectra
EMS Dispatcher
Cobb County, GA
Go to Radio Shack and get yourself some more heavy duty wire along with some butt connectors to run it to your battery. If you look under the dash (or anywhere else), you will see most of the wiring is low amperage. You don't want to fry your Exploder by a cheesy tap.
KM4WLV
Rockwell (Rowan County), NC
Mike hit the nail on the head. I don't know how many times in the years that I've been doing installing that I've seen either radios, vehicles, or a combination of both that were burned up because of inappropriate wiring. I promise that you don't have to be a mechanic to run power out to the engine compartment. Especially on a 2004 Explorer. I had one.
If you look behind the dash on the drivers side, above & slightly to the left of the steering column / linkage there is a gromet with more than enough room to run through. All you have to do is cut a small slit & there ya go. Not trying to nit pick ya, just trying to save some heartache down the line.
N2JDS
St. Peters, Mo
I have same vehicle, What I did was run I think about 4 gauge wire to battery, with a fuse at the battery. This runs through firewall, underdash, center console to under 2nd row seating, but you could do under passenger seat. Look online for a power distribution box with blade fuses for each feed you want, this box comes to be closed and safe. Then power your radio from there. Wire will be big enough you can also attach an inverter to same line. I also added a spare 12 v accessory plug too for whatever.. Plus I ran with some smaller wire another 12 v. accesory plug to the rear area, just behind 3rd row seating, which I use for emergency lighting, or you can plug a 12v fridge in or whatever.
