Power plugs for TRX-2, WS-1095, etc
rogress
Chesapeake, VA
Just wanted to pass along that I had been searching for just the power plug that plugs into the back of the TRX-2, WS-1095 and other "GRE" desktop scanners of that line. If you need just the plug, you can find it at digikey.
Digikey
These would be good if you already have the appropriate power supply and you need the correct plug, or if you need to make your own cord for your car.
YoShep69
Central Illinois
gn32772
Hartford County, CT
Hi. I have a question related to this thread. My WS1088 has rechargeable batteries in it, and i have it plugged in to an ac adapter/charger as it records all day. But when there's a power outage, the scanner turns off instead of switching to battery power. This means i lose everything it recorded since the last time i turned it on. Is there any way to get it to automatically switch to battery power in a power failure? Thanks.
