I have a 02 PT, you can see my install on my webpage but i didn't take any snapshots of the power connection underhood.
The power outlet up front, if it has the option of the accessory power outlet on the switch panel is fused for 20 amps but i looked at the wiring feeding that, its maybe 16awg, pretty small.
The other power outlet by the cupholders is fused along with the rear power outlet, 20 amp fuse for both, and its the same light gauge wire. I would get a tapa fuse and go to the fuse panel, its right there on the lower left of the dash and you can run the power wire across the dash over to the cupholders area or wherever the radio will sit. If you need more current than say 15 amps, shouldnt with even my FT-2800M only needing less than 9 amps at 60w, i would go to the battery stud in the underhood fuse panel, thats where i ran my FT-7800 off of.
