Power sorce and install 09 ford focus?
JonL008
Huntsville, TX
I am looking to install my pro-197 in my 09ford focus. What is a good way to keep power to my scanner? And any suggestions on installing it would be great as well.
pjtnascar
Sussex County, NJ
You can go directly to the battery or tap into an unused fuse in your fuse box, if there is one. As far as mounting, in that car I would try either in the arm rest or mounted to the passenger side of the console. Doesn't look like a whole lot of options with that car.
JonL008
Huntsville, TX
I just temporarily powered my 197 through a 12v cigaret plug for now. However I am getting a lot of interference from the engine. How can I stop this from happening? Also if I go directly to the battery how will I stop the interference there as well?
It is a slight buzzing/humming sound that gets stronger as I step on the gas. When I left off the gas it goes back down.
Rt169Radio
CT
Maybe its the alternator?
ERICMYERS
Plainfield, IL
Straight to the battery with power and ground, or you'll be getting alternator whine. Find a grommet in the firewall to route the wires, and fuse both power and ground at the battery. Any stereo shop could do this for you if you're not very handy.
