Power Supply for Radio Shack Pro 94
Elgin29
Hi I am somewhat in doubt as to what 9 volt DC power supply fits the Radio Shack Pro 94.
KB4MSZ
Billy
Tampa, Florida
This adapter should plug into your radio properly. However, the tip polarity is positive and would need to be reversed by cutting and splicing the wire as your radio is tip negative. This power supply has 3 times the power requirement that your radio requires so it should last a long time.
CycleSycho
Central South Carolina
:) Many quality radios have the little symbol on the socket denoting tip polarity, and a 'backplate' (mostly) has an input requirement. MAKE SURE THE A/C ADAPTER HAS AT LEAST THE MINIMUM CURRENT REQUIREMENTS (ie 500ma, 750ma, ect) I would take the above suggestion on the swappable tip polarity and then place a piece of tape on the reversible connector so someone doesn't accidentally switch it down the road. Searching the internet for an owners/users manual it best, as well. Have fun! :)
jaspence
Michigan
Original adapter was 300ma, so any good quality new one should meet the current requirement easily.
