Powering old walkie talkies with li-ion?
prcguy
These don't sound like a good idea to put inside an HF transceiver. Might generate a lot of RFI.
Actually it is not at all a 1.5V Lithium. It is a standard 750 mAh 3.7-4.2V Lithium Ion with a buck inverter inside each can.
While useful, I don't think it is a cost effective replacement for 12 AA batteries. 3 x $31 = $93 for essentially 750 mAh whereas 3 x 18650 Li-Ion are going to be much cheaper and produce much more power.
Also the 12 buck invertor's are likely to introduce some noise into the radio receiver.
KEWB-N1EXA
Acushnet Heights Radio 740
I rarely post, however this thread reminds me why I don't. I had seen the Tenavolts AA cells and thought it might help out the OP. I understand that there are no 1.5 volt Lithium AA cells, this product could work for the OP's original post. I am actually kicking myself for even trying to help.
I know how you feel but stay in the race
As they say don’t wreck the car to lead a lap!
Peter N1EXA
DaveC1964
Schaumburg, Il
I have been converting stuff to Li-Ion. I was once wary of them, but you can get batteries with protection circuits. Currently I am repacking Motorola SABER radio batteries with two lithium ion cells and a protection board. A small battery has 2200 mAH and 7.4 to 8.4V which is nearly same as the 6 NIMH cells it replaces. Works fine just need a charger that matches the chemistry and voltage.
I have a radio that runs on nominal 13.8 V . 3 Lithium Ion batteries deliver 11.1 to 12.6 V and the radio is fine with that range.
How much loss of range will I get when the pack drops to 10.5V when the radio wants 12V? Is it significant or not really from your experience?
The issue with Li-ion is that they only are at 4V for a short time. They drop to the 3.5-3.8V pretty quick, they seem to "like" being in that range longer.
I could get a DC-DC converter to keep at 12V but I am afraid of those putting out noise to interfere with the RF and will introduce a whine. Maybe they make filtered ones?
RFI-EMI-GUY
Your AA cells are going to drop to 1.3V per cell, 10.4V in constant use. You probably don't notice it until they perish.
10.5 V is slightly less than 3.7V per cell where most Li-Ion chargers will kick in. But no matter they will go deeper. I don't notice anything with a 5 watt UHF FM Motorola SABER when they approach discharge. They hold up power well. I am pulling about 3 amps perhaps 1.5C with the smaller cells.
If you have 8 AA cells in your radio, consider the capacity of an alkaline cell.
You don't need a DC-DC converter or boost circuit nor do you want one in the radio.
Just get the biggest 3 or 6 (2P3S) protected cells that fit into your space and don't worry. The technology is well beyond what alkaline or NIMH can deliver. I considered making a AA alkaline pack for my SABER radios and realized the effective series resistance (ESR) made those cells very inefficient. Lithium Ion is the way to go.
