I've been holding off posting this to confirm it wasn't an SD card issue, which I have replaced a while go. This has happened over all the firmwares, so I ruled out a specific one.
When I power on the scanner, I've had it freeze up on a system, talk group etc as if the scanner was in Channel Hold and couldn't get a signal. Another time I had the scanner scan and not stop on anything and today when I turned on the scanner, it would not receive any systems in my active trunk systems...no signal, nothing.
In order to correct this most times I had to power off and power back on the scanner. Once I had to clear out all my favorites and reload everything...fortunately I was home to do this.
Today I only had turn the scanner off and everything returned to normal. SD cards are the high performance 32gb and before I did anything else the first time it occurred, replaced it.
Very odd and can't pinpoint anything specifically that I did or have done to make this occur. My first "thought" was maybe I pressed two buttons when I powered on. I've been very careful on my button pushing and when it happened today, I know only the power button was pressed.
