Ah yes, I remember messaging with you a while back. Coming into the home stretch of getting everything configured. (Pic attached) I'll be utilizing DSD+ Fastlane, taking advantage of their new single-reciever trunk tracking feature, which should allow me to use the same hardware setup as before, but now able to feed two seperate audio streams. Previously I used two RTL Software Defined Radio USB receivers. One receiver would monitor the trunking control channel, and it would steer the second receiver to the correct voice channel, which would provide the actual audio.
Now with the new single-receiver feature, I should be able to trunk-track two discrete P25 frequencies at the same time, one on each receiver. Feed A will be PPB East Pct., and feed B will be PPB Central Pct. / PSU Police. The priority is configured so that PPB Central transmissions should always override PSU PD transmissions, but the actual functionality of the priority-jumping in single-receiver mode still needs to be tested (it works fine in dual-reciever mode).
