PPS 4.0.39 Adding TGs In P25 Trunking System Manager Doesn't Show In Existing Profile
CanesFan95
Analog already is interoperable.
FL
So let's say you add a system here with a bunch of TGIDs:
Then you bring that system into a profile here:
Then later on, you want to add more TGs in the Customer Public Resource Manager:
Well guess what? Those new TGs you just added don't show up in the zone programming:
So what is the point / benefit of using this "Customer Public Resource Manager" rather than just entering everything into the existing profile?
If you add it to the Customer Public Resource Manager after it has been imported to a profile you must also make the changes in the profile. If you have NOT added the system to a profile and add it after the change then the updates will show.
If a computer manufacturer updates a feature of your computer after you bought it it doesn't automatically show up in your computer, same principle. Likewise, if you update the database in a Uniden scanner it doesn't update your favorites list created before the database update.
Also, just to mention, the newest PPS is V41, so you are a couple versions behind, but it is the same in 41.
