PPS 4.00.35 Wont Run
Echo4Thirty
Spring,TX
Downloaded the latest PPS 4.00.35 and after install it wont open. Prompts for username and password, but then just exits to the desktop. Tried several machines, from windows 10 32 bit up to 11 64 bit. Same results. Any ideas?
Hit_Factor
Saint Joseph, MI
It wants the administrator username and password for your computer. Is that the one you entered?
I don't see that version available for download on the Unication site. Did I miss it?
According to the website,
Current PPS Programming Software: 4.0 (V0.4.0.32)​
just wondering where you found V4.00.35?
ffexpCP
wizard of odd
Michigan
Contact your contact at support, assuming you got it from legit means and proper channels. They need to know. I also had the same issue.
Echo4Thirty
Spring,TX
I'm on my phone and can't get to it. All I did was go to unication.com and downloads, then g4/5 and it took me to the Dropbox. This was yesterday at 5pm cst. I wonder if it was uploaded in error and they pulled it.
Echo4Thirty
Spring,TX
They must have pulled it. I went the same route and it's .32. The .35 version was dated 9/14 and the release notes 9/15 so I'll bet someone went whoops!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I was on the webpage yesterday and found reference to .35 as well. When I downloaded it, I got .32.
Today everything points to .32.
Echo4Thirty
Spring,TX
New PPS Version: 4.0 (V0.4.0.36)
Date: 9/15/2023
Bug/Issue Fixes:
1. Added support for profile programming on additional product models.
2. Resolved data write errors when Relay Control is set to Timeout.
3. Fixed the issue of incorrect data writing when the Knob is set to P25C mode with Squelch Option under Radio Compatible Mode.
4. Integrated a third-party certified USB RNDIS Driver.
5. Removed Windows administrator privileges requirement when opening the PPS software.
6. Resolved the issue of erroneous storage when setting a custom Alert Tone in the Pager ID configuration screen.
7. Resolved the issue where P25 Trunking System public resources could not be imported from older versions, causing errors for users who hadn't previously installed the older version.
Here are the .35 notes:
New PPS Version: 4.0 (V0.4.0.35)
Date: 9/15/2023
Bug/Issue Fixes:
1. Added support for profile programming on all product models.
