PPS communication with pager issue
whop94
Middleton, WI
Hello,
I know this has been discussed before on this thread but I am at my wits end, I cannot for whatever reason get the PPS software to communicate with the pager, it gives me the "no device connected" message when I attempt to program. This is a new issue, I have not had this problem previously and have been regularly updating my pager for the several years I've owned it, I have tried a multitude of different cables, every single USB port, uninstalled and reinstalled the PPS, tried an older version, updated the drivers, pretty much every fix I have seen documented previously. The radio is always in an on position and I can tell that the computer recognizes the device, it shows up in the device manager. Any thoughts would be appreciated!
Thanks!
N6ML
How does it show up in device manager? If it shows up under "Ports", it's not using the right driver. It should show up under Network adapters, as "Unication USB Ethernet/RNDIS". If it's anything else, I'd uninstall that device (right-click on it in device manager), then install the driver package (not PPS!) from Downloads- G2-G5 P25 Voice Pager | Unication USA
KB4SHP
Have you changed your antivirus program I have to disable my Norton before mine will work
tkowalik
Banned
I had the same problem after the windows update on 11/13. This solved the problem. Download the driver.
