Pre loaded States
N1JGE
Lowell, Ma.
After almost two days still trying to load the pre loaded state Ma. onto a bcd996xt. How soon do you use the word disgusted? From what I can see Uniden says hit scan ./no and 32. Does nothing for me. There has to be an easier way. I can use Freescan, that connects ok. All I have to dois figure that out too, as of now it does not read whatever is program from the factory.
captclint
Mountaintop, PA
Not sure why that is not working. Did you buy it new or previously owned? Also, FreeScan has an option to erase all systems 1st, and then upload. You may have accidentally selected that. There is a master reset that should restore all the preloaded systems if the preloaded sys were deleted. However, you should know that almost all the preloaded systems are way out of date. You are better of programming what you want using FreeScan and the DB
lost_in_maine
Western Maine Mountains
Not sure about Mass, but Maine wasn't one of the preloaded states..maybe Ma isn't an otion?
ecps92
Taxachusetts
Preloaded with Conventional or Trunk ? Likely Pre-Loaded from a few years ago valid data
The Mass SP trunk has had many changes in the past year and Control Channels have changed greatly, you may want to verify what you have against the RRDB and make changes
N1JGE
Lowell, Ma.
Thanks for replys guys. Going back at it today, the rig seems like a fairly new built with the latest firm ware. I thinking I'm going to dump everything loaded on it, I don't know if that's a good idea though.
JoeyC
Senior Member
San Diego, CA
Its not a good idea, Its a GREAT idea.
Preloaded data in scanners is often outdated and is not that useful. Use FreeScan and set up the systems you want and the way you want, and delete all the useless clutter out of the scanner.
wtp
Port Charlotte FL
useless or not
i just found the other unused systems to be in the way.i have a 396t and would scroll through the entire us to find a system or two and it took too long so i too wiped out all of them and then reloaded the ones i would use. think of it this way, when are you going to ______ (fill in a useless state here)
N1JGE
Lowell, Ma.
Spendt a few hours with it. Deleted every thing and reload the Mass using free scan. What I get is nothing to scan. Could not figure that one out and too disgusted to continue so tommorrow will be another day.
jaspence
Michigan
Pre loaded states
Since all of the present scanners except the newest from Uniden have been around awhile, their included databases are useless. The only way you are going to get a useful database is to create one using the RR data. Reloading just the ones you want from an old list is a lesson in futility. You might try posting in your state's forum and see if someone will send you a working compilation. It may not be exactly what you want, but if it works you will be able to base one on it.
JoeyC
Senior Member
San Diego, CA
You must assign each system or site a quick key, then you must turn the quick key on, otherwise you have a scanner full of frequencies/talkgroups but nothing is activated to scan.
N1JGE
Lowell, Ma.
Ok I think I'm well on my way. There's two videos from Free scan that gave a lot of help. There are some things I don't understand and have not been able to upload the UMass-Lowell freq, but I' scanning the area.
