President Lincoln II+ V.3
slowmover
Fort Worth
Pre-NRC type high performance. I bought mine in February 2021 as was concerned the CV19 thing would screw up the supply chain. I wanted a “best” performer for SSB while mobile.
As it is superceded by the new PRESIDENT Washington I wanted to get it into a thread of its own as I’m using it in my pickup truck. A great little radio. Get links for others. Will be several posts of such.
— To upgrade to DSP is easy for TX given that the Digi-Mic is available. To upgrade RX audio is a good deal more expensive with several paths.
You may have found a low-use Lincoln at a great price.
Introduction:
President (Lincoln II Plus) - AM/FM/USB/LSB/CW/PA, Black, 10 & 12 Meter Amateur Mobile Radio
Description:​
Welcome to the world of the new generation of transceiver radios. The new PRESIDENT range gives you access to top performance transceiver equipment. With the use of up-to-date technology, which guarantees unprecedented quality, your President Lincoln II Plus ASC is a new step in personal communication and is the surest choice for the most demanding of amateur radio users.
Visit The President LINCOLN II + Resource Center located at President-Electronics.com for the 'latest' including programming instructions and software (Documents Tab).
Please Note: Programming Cable is not included with the Radio.
PRESIDENT - More than a name, PRESIDENT is the representative of the Citizen's Band which unites millions of CB users all over the world : drivers, purists and technology fans.
Features and Specifications:​
  • 10 & 12 Meter Mobile Amateur Radio
  • AM/FM/USB/LSB/CW/PA
  • Rotary Switch and Up/Down Channel Selector
  • VFO Mode (Continuous Scanning of 24.890 Mhz to 24.990 Mhz and of 28.000 Mhz to 29.700 Mhz)
  • Volume Adjustment and ON/OFF
  • RF Power
  • Manual Squelch and ASC
  • Multi-Functions LCD Display
  • Frequencies Display
  • S-Meter
  • Public Address
  • Vox Function (Hands Free)
  • ANL Filter , NB and HI-CUT
  • RF Gain / Mike Gain
  • Clarifier
  • Channels and Memories Scan
  • 6 Memories
  • CTCSS (38 tones)
  • DCS (104 codes)
  • Dim
  • MENU Function Key
  • Beep Function
  • Roger Beep
  • Mode Switch AM/FM/LSB/USB/CW
  • Dual Watch
  • Key Locking
  • SWR (Power Reading /SWR)
  • Preset 9/19
  • TOT (Time Out Timer) Adjustable
  • Front Microphone Plug
  • External Loudspeaker Jack
  • Dimensions H x W x D (in mm) : 52 x 170 x 250
  • Dimensions H x W x D (in inches) : 2 3/64" x 6 11/16" x 9 27/32"
  • Weight : 1.4 kg
  • Weight : 3.09 lbs
  • Back Light Color: Orange, Green, Blue
  • Included Accessories:
    • Power Cord with Fuse
    • 1 Microphone and Its Hanger
    • 1 Mounting Bracket with Fixing Screws
  • Technical Characteristics:
    • General
      • Modulation Modes : AM/FM/LSB/USB/CW
      • Frequency Ranges : 24.890 Mhz to 24.990 Mhz and of 28.000 Mhz to 29.700 Mhz
      • CTCSS : 38 tones
      • DCS : 104 Codes
      • Antenna Impedance : 50 ohms
      • Power Supply : 13.2 V
    • Transmission
      • Frequency Allowance : +/- 300 Hz
      • Carrier Power : 50 W AM (PEP) / 35 W FM / 35W USB-LSB (PEP) / 12W CW
      • Transmission Interference : Inferior to - 50 dBc
      • Audio Response : 300 Hz to 3 kHz
      • Emitted Power in the Adj. Channel : Inferior to 20 microW
      • Microphone Sensitivity : 3 mV
      • Drain : 6 A (with Modulation)
      • Modulated Signal Distortion : 2 %
    • Reception
      • Maxi. Sensitivity at 20 dB sinad :
        • 0.7 microV -110 dBm (AM)
        • 0.35 microV -116 dBm (FM)
        • 0.28 microV-118 dBm (USB/LSB/CW)
      • Frequency Response : 300 Hz to 3 kHz
      • Adjacent Channel Selectivity : 60 dB
      • Maximum Audio Power : 3 W
      • Squelch Sensitivity :
        • mini 0.2 microV - 120 dBm
        • maxi 1 mV - 47 dBm
      • Frequency Image Rejection Rate : 60 dB
      • Intermediate Frequency Rej. Rate : 70 dB
      • Drain : 400 mA nominal, 600 mA max
  • UPC 3435991326025
  • Color: Black
  • Manufacturer's Limited Warranty - 2 Year(s)
  • Sold: Each
Price at end is (retail) $356 and when I bought mine was as low as $260.
slowmover
Fort Worth
Single DIN mount bracket for in-dash
PRESIDENT 0014
https://www.bobscb.com/PDGImages/V051/fonctions_TXSE041_EN.png1744430999393.png
slowmover
Fort Worth
From Britain:
Conversion
This video shows how to modify a President Lincoln II radio to receive on the 11-meter band. The process involves adding a 1K resistor and soldering it to the radio's circuit board. The video then demonstrates how to reset the radio to access the new frequency band
slowmover
Fort Worth
L2+ commentary now NRC radios dominant. Overview, align, etc (24” long). Scott’s Radio in 2024 on a “new” radio. Fairly long section on running with amp AM & SSB.
slowmover
Fort Worth
More from same:
I’ve run the L2 with either an RM Italy KL-203 or 7405. It’s finicky to get right. As it’ll (on its own) do 45W it’s really a matter of getting your mobile install best as well as best antenna system design. Those who can hear you in a major metro are going to be closer, meaning that with those farther out it will be difficult to converse.
The other mans radio system (is the problem).
Rural is where yet more juice will apply, as it would with Sideband.
The video discussion referenced a KL-503HD.
slowmover
Fort Worth
slowmover
Fort Worth
Audio
The PRESIDENT Lincoln II+ V.3 suffered from what’s been called, “the digital hiss” it shared with tech contemporaries (circa 2008 and later) making all-day listening a chore unless one learns to adjust controls differently.
On a typical mobile CB (Cobra or Uniden or Galaxy) one looked for a fairly quiet channel and adjusted RFG such that the meter backed off a minimal bit and then adjusted SQ such that most signal wasn’t lost. Then went back to AM-19 to maybe twiddle that some more.
With Lincoln it’s better to simply start by backing RFG to 3/4 of maximum on 19 and maybe go to SQ-1 as start position depending on rural or metro, Skip or no Skip. Back RFG yet more if that doesn’t suit as the RX is pretty hot and one isn’t likely to lose anything.
The L2 presents all signal capture at “same level” so both SQ & RFG aren’t intuitive in the way one has learned previously. There’s a middle distance for which it shines, but it seems like there’s still too much overlay of hiss once correct.
One needs DSP in the audio:
— “Best” would be the outboard West Mountain Radio control or the internal module thru a DRIVER EXTREME DRX-901 speaker.
— Second would be with the W-M DSP speaker.
As well — as with all radios — coax treated at both ends with CMC/RF Choke/Filter and dead-quiet DC Power. (Bandpass Filter for those so inclined).
RF Bonds
Radio case ground.
Environmental Noise really takes a toll on one’s ears these days, and a radio with “digital hiss” (without onboard NRC) needs as much help as possible.
Given this approach I’d say the QT60 isn’t really “better” until we are talking ultra-long range RX in a mobile. The QT60 always has an edge in clarity over trying to control hiss, but one gets used to it. The L2 can be made to work well if we don’t try to hammer performance to a standard of rigor.
I’d rather listen to my GALAXY 959 + KL203 all day, but I know I’m giving up a pretty good amount of RX capture while mobile. I used to make that choice as it was also easier to distinguish between local and Skip. But if there’s any possibility of needing to use SSB on-road, the L2 is the way to go (until one acquires an NRC AM/SSB radio).
As an intermediate step from the 959 to QT60 the L2 serves well and enables use of PRESIDENT optional accessories (Liberty DECT mic & Digi-Mic). Important to me. I also run a 7’ PRESIDENT antenna.
I’ve gotten inquiries about what radio I’m using as L2 has a different “sound” which helps get attention assuming one has worked to quiet any background and/or radio system “noise” on key-up. As with NRC radios — when one’s voice arises from a background of silence — this attribute works to one’s favor.
Fast acquisition of proper information while mobile is the whole game. Everyone is moving away from everyone else at a high rate of speed. It’s a window which opens & closes rapidly. One may have only seconds to connect to others.
The L2 is a good radio for this.
It’s the SSB King circa 2012-2022.
AM/SSB, adequate power, and can be made to be competitive in Distant Early Warning given additional DSP expense I don’t feel I’m giving up much in my personal vehicle to travel national-wide.
Taming the audio such that the radio stays turned on all day can be done.
slowmover
Fort Worth
A note by another that this radio does well using Digi-Mic and an Echo setting of #2.
Digi-Mic isn’t amplified, but these radios as a group were known to “sound better” (the old standard of “stadium announcer”) using a power mic.
I’ve already done the mic mod on the OEM of opening up slightly the mic hole. It’s an electret mic and captures wind noise. And it can help to speak across the mic at an angle versus straight ahead.
— One should use a headset from another radio to dial-in what angle & distance.
Digi-Mic is what keeps L2 in the game.
Gets attention.
slowmover
Fort Worth
Instruction Manual
This is not a mobile-friendly radio for controls. It’s best to keep the operator manual at hand in order to pull off the road and re-set anything not Vol, RFG, SQ as menu functions and other buttons need visual confirmation on the small screen past how to get to them.
One sets this up at home and then doesn’t change it. With that there’s no need to get into it.
It pays real dividends to use that second radio & headset to get comfortable on Mic Gain, etc.
If one has to use Talkback, Echo, Roger Beep, all the more so.
I’ve used those to have fun with other drivers. The Galaxy 99v2 was real fun to mess with Nu Joisy drivers on the INTJ given the voice-changer. Not this radio as they are a distraction from what I want.
— I’d go with a powered XTREME 2018 mic (re-wired or with adapter) to mess with friends on a regular basis as it’s more than a clown tool. Can be set to sound quite nice. There are those who buy it for just that reason.
slowmover
Fort Worth
Skip
Is The Bear
An understanding of the difficulties:
Your antenna system being without compromise is key.
NMO34 + W640 whip + Spring will be the longest-lasting and ultra low-key approach. Whip can be removed and replaced with cap.
The reason for wanting an L2 is distance.
slowmover
Fort Worth
Speaking of which . . .
The low levels of Skip in my region of late have improved my local capture significantly. As I live in a neighborhood below a ridgeline separating us from the Interstate I thought that barrier was primary to why the travelers faded so soon in my RX once I was driving away at a right angle.
Instead, I’ve been able to (again) re-adjust SQ & RFG to maximize “local” (beyond 5-miles) daytime on AM-19 in a satisfactory way.
This radio plus the same manufacturers 7’ antenna are a better pair than I’d suspected.
slowmover
Fort Worth
Was in town doing some errrands. Not far from Interstate.
Heard pilot car guiding OVERSIZE onto the big road from southbound, and then they drove past me going west. A little over three miles of road driven.
What’s interesting about President is that they (3-4/men) didn’t change in “volume” the whole way. I couldn’t have told you they’d gotten closer or had passed me.
I was moving and so were they (I had stoplights on frontage road).
Most radios they’d have gotten louder (and clearer) as they came nearer. Then decreased in volume having overtaken.
Radio set with noise aids. DSP Speaker in use. SQ set to Setting One (had some Skip today; minor). During this time they were On-Air was no one else to be heard. At all.
Easily, this sounded as good as with any radio I’ve used, and almost better than all. Couldn’t have told you what Pilot was using, but I’d bet it was NRC-equipped (they were busy and so was I so no inquiry made).
Trimmed the T-1800 antenna a few days ago to an almost imperceptible lower than 1.2:1 by lengthening whip to change antenna length from 83.46 delivered to 84.50 tuned.
It has taken me awhile to “know” what to twiddle in order to accentuate RX according to location and conditions. From below topo average elevation to being far above it (broadcast towers); to try to differentiate between minimum four (4) Interstates; and Skip versus local.
Now that it’s easier (my guesses of Who, What, Where) this radio continues to surprise.
slowmover
Fort Worth
More on Controls:
Compared to a C29 or C148, this radio is a Porsche where some inputs for performance are a real change:
I’ve recommended that one carry the Op Manual along in the vehicle as — in comparison to a more common Export — the range & depth of controls can be more than one wants for Mobile CB while moving. It’s the How To in terms of settings this post addresses a second time and hopefully with better depth.
Once menu settings done to satisfaction it’s back to the front plate. Assuming I’m staying on AM (use Mode switch to left of Volume knob), one is pretty much only going to use RF Gain (set “back” to 3/4-mark, generally) and SQ.
The PRESIDENT version of such features ASQ (will let you look that up) and it’s the single radio control which I manipulate going from worse to better and back again re terrain conditions with major metro noise a close second.
I’m also adjusting the DSP Filter on the outboard extension speaker in response to the same two.
In the previous about Near/Far not changing RX much — this is a bit uncanny compared to other radio brands — it feels confusing to not alter what I’m hearing. Takes discipline to leave alone the controls once right RFG setting found.
SQ
to 0 or 1.
It’s a constant temptation to mess with Vol, RFG & SQ and nothing seems to change. This is mainly Skip versus Local. If anything, back RFG farther as this radio will present all RX capture at the same “intensity”. A counterintuitive move compared to some radios. What we want is Local as our guide to thinking about controls.
This makes more sense — “equal RX capture presentation” — as a hobbyist trying to work 10M to make contacts versus Roadway Robert sorting traffic reports who is relying on Near/Far signal strength indications.
This “difference” isn’t any perfect rendition, it’s meant to be emphasis on how to alter settings for roadway use. Rather, how to leave them alone once one has dialed-in known settings. Those known settings being Terrain & Metro, afterwards, let the radio do its job.
My earlier post about an OVERSIZE going past at a clear, noise-free and with optimal clarity “tone” (DSP Audio wanted) the Lincoln II+ doesn't seem to give up RX performance in a pickup with a roof-mount 7’ antenna. (My mobile antenna system close to, “can’t really be improved”, with fixed givens).
I haven’t said it’s as good as the latest new device circuitry NRC radios of comparable spec & quality, and won’t. What I’ve said before is that an orphan cousin of my radio may pop up and if you think it’ll do a good job for you in second-line operation . . . you’ll be right.
What’ll have discouraged the original owner for mobile ops is what I’ve tried to describe, and how I’ve worked things out to meet a 48-state truck driver expectations given already extensive use of different radio brands & spec and with DSP Audio previous to the advent of NRC.
The following is How to Think:
1). RFG to 3/4.
2). SQ to 1
3). Audio thru a HQ speaker (preferably DSP).
4). Adjust to Terrain/Metro.
While within Terrain/Metro pre-set:
A). Favor Local.
B). Back RFG to find out.
C). Then bump up SQ.
slowmover
Fort Worth
Post in thread 'DSP Kit'
DSP Kit
The DSP kit is what I should fit to the Linc.
(Have to find tech to do work).
With Digi-Mic I have covered RX & TX via DSP.
Can then switch to DRX-901 speaker.
slowmover
Fort Worth
A recent SCOTTS RADIO video his having acquired some NOS units. Depth & detail:
