I have what I think is a simple question but I have been unable to find an answer for.
The President McKinley CB Radio is specified as being compatible with either 12 or 24 volt systems. Does this mean I can assume that it will work at any voltage between these values? Here is what the manual states:
"Your PRESIDENT MC KINLEY USA 12/24 V is protected against
an inversion of polarities. However, before switching it on, you
are advised to check all the connections. Your equipment
must be supplied with a continued current of 12 or 24 volts"
The last sentence doesn't really make sense to me technically. The reason for the question is for the possibility of running the radio on various cell count batteries between the 12 to 24 volt spec.
