Presidential Debate CAP
LFRfreak
Mount Juliet, TN
BTFire21,
This is awesome!! What's your radio/antenna setup? Do you have any tips for quickly locating the active frequencies for a given flight? I will likely have an opportunity to listen in when the debate is held in Nashville and I want to be prepared.
Thanks in advance!!
CORN
Norfolk, VA
BTFire21,
Thanks in advance!!
Will you be in/near Nashville? Highly doubtful you’ll wrangle it in from Texas. If yes to question try 260.9, 228.9, 364.2, air to air prob depends on which unit gets the CAP duties IF there is one in the first place.
LFRfreak
Mount Juliet, TN
Yes, I'm near Nashville... I need to update my profile. Thanks for the freqs.
wxwarn285
Middle Tennessee
Since when did the civil air patrol (CAP) start using frequencies in the 200 and 300mhz bands? I thought they could only use the 143ish, 141 and 148ish frequencies.
RichardKramer
Reading, PA
This CAP stands for Combat Air Patrol. Military a/c protecting assets that are on the ground. These a/c will also use the 138 - 143.975MHz band and 148 - about 150.8MHz band, mostly in the AM mode. The above mentioned freqs are the more common ones used.
Rich - N3VMY - KAG0096
wxwarn285
Middle Tennessee
Thanks for the clarification, I never have heard of this sort of CAP till now.
Hooligan
Clark County, Nevada
And I guess you didn't see/understand the references to "fighters," "F15" & "refueling" but besides all that, some Civil Air Patrol aircraft & ground stations have had 225-400MHz military aircraft band transceive capability for at least a couple years. The Nevada Wing in Southern Nevada refers to their discrete channel in the 225-400MHz spectrum as "Uniform." CAP Nevada Wing is somewhat unique because of their support to GREEN FLAG training.
