Primary Control Channels
kirkman123
Ishpeming, Michigan
Just out of curiosity, has anyone out there bothered to make a list of all the Primary Control Channels for Michigan? If someone has such a list, I'd appreciate having a copy. It seems to me that it would be very convenient to plug in all the control channels, and as you travel around the State you'd have fairly constant coverage.
Thanks in advance.
Kirk
Ishpeming
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
These are from the DB in Excel. Several freqs are used by many sites. Site numbers are associated with the freqs.
kirkman123
Ishpeming, Michigan
fmon,
That list was EXACTLY what I am looking for. I knew I could copy all the control frequencies from the "master list" at RR and then eliminate the duplicates. However, I assumed that someone had already done that. Your Excel list accomplishes what I wanted to do. I was just too lazy to do it myself.
Thanks much
Kirk (also retired again and again and again........)
KDT
MSPCS Control Channels Zip
I would like to try that list myself. But I got a question.How would I import it into Win96?I didn't think Win96 supported Excel files.Would I have to save it to another format before I import it ? Thanks Keith
fmon
Eclipse, Virginia
In the Excel click on column A->Copy->in Win96 click Edit->Paste.
KDT
OK .Did that Thanks, But what are the other numbers in the other columns do I need those
fmon
Eclipse, Virginia
Site numbers for the towers. No you don't need them. If you need a tag for the freqs in Win96, MPSCS is about all that would id the sites, cause 868.4500 is used by 11 sites.
