Print screen software
n9mxq
Belvidere IL
Hit CTTL - PRT SCR, then open paint and hit CTRL-V..never needed a program..
sent from an electronic device...
n9mxq
Belvidere IL
No biggie Larry.. Glad I could refresh your memory..
questnz
Snagit will be the best and most comprehensive and complete software here but it cost.
Chris
CapStar362
GA, USA!
paint.net is free
CTRL is not needed for the PRT SCR command key. just simply tap PRT SCR to grab whatever is viewable on your screen and copy a image to the Windows Clipboard. CTRL + SHIFT will activate the Sys RQ function which is older IRQ HALT invoke key that was just never taken out.
it is still present in modern LINUX systems though.
moonbounce
How do you paste it. For example, if I want to paste it in a new RR thread, how would I do that. I can copy it to paint, but I don`t seem to be able to move it form there, thanks.
Moonbounce
moonbounce
I know I can do that but that isn't what I want to do. What I want to do is print screen and paste it into a form like RR?
n9mxq
Belvidere IL
In order to cut and paste you have to highlight the information you want, then right click and select copy, then go to the form you want and right click and select paste.
A screenshot will not do this as far as I know
bravo14
Polk County FL
I try years hitting CTRL Print Screen and go to the paint program nothing happen so I've been using this software (Gadwin Printscreen) for years its free and works good.
frazpo
SW Mo
Print screen then go to paint and paste it to a new file. I use dropbox for cloud storage and it automatically saves it to an image file right when you hit print screen. Pretty nice.
CapStar362
GA, USA!
bravo when you press PRT SCR that takes whatever is on your display and puts it on the "clipboard" you have to paste those contents from the clipboard to the image program you use.
again, CTRL is NOT needed for PRT SCR
cg
Connecticut
PrtScn to copy the entire visible screen but if you only want to copy the active (topmost) window, use ALT-PrtScn. It saves some cropping if you are only interested in one window.
chris
Blackink
Central Vermont
If you use 2 monitors, it makes a difference what you press in order to "capture" the active screen.
Pressing just the print screen button will capture both monitors.
Pressing Alt + Print screen will capture whichever screen is active at the time.
CapStar362
GA, USA!
true, but CTRL does nothing to PRT SCR.... CTRL will activate the SYS RQ function present in Linux/Unix/ and very old versions of Windows and Dos
rcool101
Eastern Ohio
This was something I've been looking for. Thanks
