Priority Channels In Talk Groups, 396T
ScannerWayne
Mobile AL
Ok... I've looked in the manual, I've read through most of the threads here and searched elsewhere and have seen nothing on this particular problem.
I have the 396T, Firmware version 2.00.07. Updated the firmeware without any problems.
Priority channel selections in a trunked system. I have found no way to do such a thing. In conventional systems I have no problem in designating a priority channel.
Can anyone tell me how, in a trunked system, I can designate a priority channel(s)?
Thanks...
KI4LIV
Melbourne, FL
I hate that they did this to the 396T and 330T.
On my old BC785D I found a way to do it, but I don't think it was documented. You would have to be in ID hold mode on a talkgroup OTHER than that which has priority within the scan list. Then if something came up on the priority talkgroup it would jump over to that one.
I really miss this capability though. Damned shame that they stripped it.
kennyloatman
Cumberland Co., NJ
The priority also works on the 796D trunked systems. It samples the priority channel for activity everytime it goes back to the control channel between conversations.
KI4LIV
Melbourne, FL
Still a shame that they removed this from the newest line of scanners. I used priority all the time with my older scanners.
rdale
Lansing, MI
It really doesn't alter a whole lot... It doesn't do an interrupt like conventional channels or the PSR500.
rdale
Lansing, MI
It would be doubtful since it has to interrogate the low-speed data flow on the voice channels, and that's more than just adding a few lines of code :)
KI4LIV
Melbourne, FL
I don't see what the big deal is honestly - the older scanners did it - why use what the older ones did as a base-line when making the new?
rdale
Lansing, MI
The older scanners DIDN'T do priority. They simply checked for that talkgroup one more time. That really has no value.
powerhouse
Manchester,Maryland
I too couldn't believe it when I realized that you couldn't do this with the 396.
I had just finished setting up my psr500 with all of the priority channels I wanted,(both conventional and trunking talk groups), and tried to do the same with the 396. Why this seemingly basic feature/function is not included bewilders me.
KI4LIV
Melbourne, FL
They allowed you to "Park" on a talkgroup that wasn't priority, and still checked the other talkgroup that was set to priority for traffic on a repeating interval.
Call it priority, call it picking your nose, call it what you will, I don't care what you call it - it's something that the older scanners had that was a useful functionality.
