Priority Scan Interval?
MichaelC34
Boston, MA
Just wondering what some of you may set your Priority Intervals at? Im finding it quite annoying that PRIORITY SCAN keeps interrupting my scans just to scan PRI… any thoughts?
ofd8001
Louisville, KY
I think the range for Set Interval is 1 to 10 seconds. Ten seconds may be least disruptive, but most transmissions are much less than that. So you might end up missing "stuff" and moot the whole purpose of priority scanning.
About like any other setting, one size doesn't fit all. Just gotta try and see what suits you.
n1chu
Farmington, Connecticut
Does the 325P2 have a DND (do not disturb) Priority setting? If so, its the next best thing to the basic Priority setting that causes the scanner to jump to a priority channel every so many seconds, even while the scanner is stopped, listening to a busy channel. With DND the scanner will only check the priority channel(s) when there is no other activity. You may miss something on your priority channels while the scanner is sitting on a busy channel but at least it gets rid of the “popping” back and fourth between a busy channel and the priority chsnnel(s) you have activated.
MichaelC34
Boston, MA
yeah i think 5 seconds would be an ideal start thanks everyone!
