Private feed questions
dispatcher812
Connecticut
I am looking to set up a private feed using my 536 and I have a few questions. I want to be able to stream but also be able to control the scanner as well from anywhere. I would also like to be able have a virtual image of the scanner so I could actually "see" the scanner and what system its on.
What is the best software that will do all this? proscan, butel, other?
Does the Arc software for the 536 assist with streaming?
a388sig2
Would video streaming over a password protected UStream account work with Remote Desktop access?
I too am looking for a similar private solution.
n0nhp
Grand Junction
ProScan is what you are looking for.
ProScan
Allows all that you are trying to do.
To see what other scanners look like, if you want to make the stream public without others being able to control your scanner, download the free client.
You don't have to make the stream public, but some of us do.
Bruce
n0nhp
Grand Junction
"BCDX36HP support will be out before end of May.
BCD536HP First Look"
dispatcher812
Connecticut
ARC software and TeamViewer
I thought about this. I used Team Viewer in college for a lab. The problem is want to be able to control the scanner from work and I can't put Team Viewer on my computer here.
Does the ARC software allow streaming? I could not find anything that said it did.
