Pro-106 9 Volt Adapter
John2008nj
South Plainfield, NJ 07080
When you buy a power adapter from Radio Shack for the Pro-106 hand held scanner, Make sure you use the "C" plug with the power adapter. This is the correct plug that will fit the scanner. If you use the wrong plug it will not charge or power the scanner.
John
