GeneseeCoMI
None of the buttons on my Pro 106 are working. No the keypad isn't locked. What do I do?
Here's how to reset...What do I do?
Initialize The Scanner (TOTAL RESET!!!!!!!)
1. First turn the scanner OFF then back on again.
"Welcome To Digital Trunking" will display
2. Press the 0 button. "System Tests; Select Test; Exits if no Key Press" will display.
3. Press the number 1 button. "Factory Init; Erase Memory; ENTER if Yes; CL to Exit" will display.
4. Press the ENTER button. "Initializing; Clr Main Mem; V-Scan is OK; Please Wait" will display.
Wait until the initialization of the scanner is complete before turning it off. When the scanner has finished initializing, "M000" will display on the top line and "Bank 0 Ch 00" will display on the bottom line.
Consider purchasing Win500 if you have not already done so to back up your memories
Fair enough, Amazon linkI don't have an ebay account (I prefer Amazon). I was hoping there's another fix without having to spend any money.
Don't know a free fix without losing your memories, sorry
Turn off the scanner. Turn on the scanner. At the welcome screen press and release 0 and then press and release 2. That will reset global settings to factory defaults without erasing the memory. Before you do that, let me know what is displayed on the screen. You sent your last post just before I did mine.
That doesn't sound good. It wasn't dropped or water damaged at any point was it?
Here is something I found that may be of interest:
