P
PolarBear25
Guest
3 things my PRO-2052 will do my PRO-106 will not
1. The PRO-106 will not tell you the other Voice Channels (VCs) that are active while the current talk group (TG) (TGRP) your on is at idle.
2. You can not go directly to a object such as a talk group (TG) (TGRP) by pushing the number keys, or manual so if the 5-way directional keys go out, you can not go to a object directly. MAN (or PROG), FUNC, the object number and then ENT is the fix to this FYI.
3. If your on manual on a idle talk group you can not activate the priority (PRI) function, And if the talk group (TG) (TGRP) is at idle, and a priority (PRI) talk group (TG) (TGRP) goes active the radio will not switch to the active talk group (TG) (TGRP) if the priority (PRI) function is active.
The pros out way the cons, On the PRO-106 but this is an FYI post for persons planning buying this radio.
