KC9UNK
Does anyone know of a program for download, (virtual controller) for the pro 106 that isn't a time demo?
I just asked a simple question for link not for personal antic or opinions thank you! If you don't have the info then why comment?
Thank you for the info Ronnie. Im okay with the software I have,its already programmed I was just looking for a controller.
I tried scanbuddy and I must be missing something cause its not finding my radio or anything,i did the set up and its not doing anything and I don't see a tab such as activate or something along those lines
Yeah there is no start button anywhere on that scanner tab screen. I know I have the right cable and drivers cause iv used other programs but they were all time restricted so that's why I was looking for something else
Well, I don't know what to tell you. On my copy, when I click the "Scanner" tab, there is a "Start" button there.... clear as day.
I don't have the start button either.
I might be wrong, but after comparing the two screen-shots in the earlier posts, in your screen-shot it seems that the application has not been expanded to full screen, because the white text box (to the left of the buttons) is cut-off by the lower border of the application, whereas the other screen-shot shows the proper lower edge of the text box. If possible, try to expand the lower border of the application so that the entire white text box is revealed, and maybe the Start button will display as well.
Hope this helps,
