Yes they did recently I believe it is digital not sure if its trucking or conventional
This is the new license:
FCC Callsign WRDD860 (DEWITT, COUNTY OF)
www.radioreference.com
It's licensed as conventional, not trunking. I don't see DMR or NXDN emission codes on the license. Just analog & P25 digital. There are a number of frequencies on that license that are not in the database. I'd suggest programming in the ones that do not show on the database page for the county. Look for the station type as
FB2, which is a repeater.
Program the unlisted ones in your Pro-106 with the 'Squelch Mode' set as Search. That way, the scanner will catch it regardless of whether they are using analog, or P25 digital conventionally. If the scanner finds one, you'll see the PL tone, DCS, or NAC code being used.
Currently, there are no public safety related frequencies in the county that are licensed for a trunked system. Of course, that does not eliminate the possibility they are using them that way, but they are not licensed for trunking.
Remember to submit any new frequencies that you find in use to the database so that it can be updated.
