walter900
- Joined
- Aug 24, 2005
- Messages
- 220
I thought i would start a firmware 1.7 wish list thread.. Now that i've had a chance to become quite familiar with this wonderful radio.. I have a few "realistic" suggestions for GRE to consider to make it better.
My suggestion;
"A Global on/off for "backlight attatchment to active scanlist objects".. That does not effect (shut off) the LED like stealth mode does." So that some will not get confused here.. I am not talking about the LED attatchment to scan list objects that leaves the LED on after a transmission.. I am talking about the backlight attatchment only.
Here is the scenario just in case some folks do not fully understand what i mean.
I have programmed the upper backlight to turn on with all active scanlist objects (1,000+).. I also have seperatley set the LED to come on (various colors) for all active scanlist objects as well.. Now answer this one, how can you turn off just the "backlight portion only" from lighting up on all active scanlist objects without also shutting off the LED as well. You can't do it, unless perhaps you a create a second Virtual Folder that has all of the backlight to active scanlist objects set to off.. And If you use stealth mode, you lose the LED as well from lighting up.
My suggestion;
